GameStop GS3 GameCube Controller Motherboard Replacement
  1. GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: step 1, image 1 of 2 GameStop GS3 GameCube Controller Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Open the controller by unscrewing the screws located on the back panel
    • Separate the two halves of the controller.
  2. GameStop GS3 GameCube Controller Motherboard Replacement: step 2, image 1 of 3 GameStop GS3 GameCube Controller Motherboard Replacement: step 2, image 2 of 3 GameStop GS3 GameCube Controller Motherboard Replacement: step 2, image 3 of 3
    • Remove the rumble-pack by unscrewing the screws located on on either side.
    • Remove the rumble pack to fully separate the two halves of the controller
  3. GameStop GS3 GameCube Controller Motherboard Replacement: step 3, image 1 of 3 GameStop GS3 GameCube Controller Motherboard Replacement: step 3, image 2 of 3 GameStop GS3 GameCube Controller Motherboard Replacement: step 3, image 3 of 3
    • Disconnect the motherboard from the front half of the controller by unscrewing the small screws around its perimeter.
    • The motherboard should separate and lift right out from the front half.
John Harrison
213 Reputation
2 Guides authored
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 22
All Time: 667
