Garmin 830 Display Replacement
  1. Garmin 830 Display Replacement, new replacement display: step 1, image 1 of 1
    • In my case I got an disply from ebay, the quality seems like the original
  2. Garmin 830 Display Replacement: step 2, image 1 of 1
    • The screen is bonded in. you can get it out with heat like common smart phone displays
    • In my case, I forced it out with the shown plastic tools, as it anyway was broken
  3. Garmin 830 Display Replacement, removing old glue residues: step 3, image 1 of 2 Garmin 830 Display Replacement, removing old glue residues: step 3, image 2 of 2
    • remove the residues of the glue. I used alcohol and a blade
  4. Garmin 830 Display Replacement, connecting and glue in the new display: step 4, image 1 of 3 Garmin 830 Display Replacement, connecting and glue in the new display: step 4, image 2 of 3 Garmin 830 Display Replacement, connecting and glue in the new display: step 4, image 3 of 3
    • connect the 2 different FPCs. Blue to blue and red to red circle.
    • glue and seal the display. In this case T-700 was used
    • let it set, you're done!
Daniel Alexander
484 Reputation
2 Guides authored
5 Guide Comments
Hey! How do you suggest getting the screen off if it’s not as shattered at yours?. Picking away at the crack? I would post a pic but not seeing how to do that… I’m going to attempt. Figure local cell phone repair places will charge half its value if they’ll even do it.
Thanks!
John Hoffmann - Reply
Hi John, I haven't personally tried this repair, but I'd say something like our iOpener would work great.
Amber Taus -
Are you able to provide the name of the eBay seller? Thanks!
Nathan Perrin - Reply
I replaced the screen but the new touch screen doesn't work, is there a calibration required or do you think I got a new screen with bad touch sensor?
Ricky - Reply
Ricky, likely it's because many capacitive touchscreens rely on proper grounding through the device’s chassis or frame. I, too, replaced a screen a few days ago and also found out that the touch screen is not registering any touches when the new display is connected to the main board and not seated into the device enclosure (not needed to be glued to try out).
Vitaly Lysenkov - Reply
Past 24 Hours: 8
Past 7 Days: 45
Past 30 Days: 144
All Time: 15,420
