Garmin 910xt GPS Front Casing Replacement
  1. Garmin 910xt GPS  Front Casing Replacement, Preparing the new casing: step 1, image 1 of 1
    • Prepare the new casings to be used and all your tools.
  2. Garmin 910xt GPS  Front Casing Replacement, Dismantling the Garmin 910xt: step 2, image 1 of 3 Garmin 910xt GPS  Front Casing Replacement, Dismantling the Garmin 910xt: step 2, image 2 of 3 Garmin 910xt GPS  Front Casing Replacement, Dismantling the Garmin 910xt: step 2, image 3 of 3
    • 1. Remove the strap first
    • 2. Use a T4 or T5 star screw to remove the screws on the old garmin 910 device
    • 3. Use a small sharp knife or swiss knife and gently insert on the bottom part as shown and lightly twist to unlock the case. Once unlocked, use your hands to force open the casing to minimize damaging of the rubber part
  3. Garmin 910xt GPS  Front Casing Replacement, Swapping the front cover: step 3, image 1 of 3 Garmin 910xt GPS  Front Casing Replacement, Swapping the front cover: step 3, image 2 of 3 Garmin 910xt GPS  Front Casing Replacement, Swapping the front cover: step 3, image 3 of 3
    Tool used on this step:
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • 1. Once the casing is opened, gently remove the lock from the flex film of the battery to the mother board.
    • 2. Gently remove the LCD and move it to the new housing
    • 3. Before locking it all in, use a microfiber cloth and wipe all the dirt on the lcd and the screen
  4. Garmin 910xt GPS  Front Casing Replacement, Assembly: step 4, image 1 of 3 Garmin 910xt GPS  Front Casing Replacement, Assembly: step 4, image 2 of 3 Garmin 910xt GPS  Front Casing Replacement, Assembly: step 4, image 3 of 3
    • 1. Please make sure to check if all buttons are working and not stuck before closing the covers
    • 2. Use your T4 or T5 star screw to put back all the screws in place
    • 3. Make sure all the components are neatly fixed & tucked in before locking
    • 4. Return back the straps
  5. Garmin 910xt GPS  Front Casing Replacement, Final Check: step 5, image 1 of 2 Garmin 910xt GPS  Front Casing Replacement, Final Check: step 5, image 2 of 2
    • 1. Scan through the device to see if there is anything loose
    • 2. Check charging also
  6. Garmin 910xt GPS  Front Casing Replacement, Test the GPS Finale: step 6, image 1 of 1
    • When all data fields show up, that means GPS is connected and you are good to go!
6 other people completed this guide.
Ian
268 Reputation
1 Guide authored
9 Guide Comments
The only question I have is about waterproofing after the back cover is screwed down. Is there any cement between the back cover and the case?
Gerald Jankowitz - Reply
voces possuem uma carcaça de garmin para mim vender, doar / sou do Brasil, minhas cachorrinhas como os botões do meu garmin
lana313 - Reply
Lana 313, eu tive um problema com a caixa frontal do 910xt. Comprei essa caixa frontal com a proparts, autorizada da garmin no Brasil. Tudo custou 355 reais ( case frontal + lente + frete ). Você só precisa abrir um chamado na proparts, enviar as fotos e informar que precisa de uma nova caixa frontal (esse eh site deles https://proparts.desk360.com.br/app/auth...).
rafaelzinho_costa - Reply
Great fix! I will do the same as soon as I will get the new front case! (ordered from ALiExpress… wish me luck!!! LOL
I am also keen to know if you put any cement/putty between front and back case… anything?
Ivan - Reply
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 55
All Time: 7,708
