Garmin Dash Cam 20 Battery Replacement
  1. Garmin Dash Cam 20 Battery Replacement, Internal Assembly: step 1, image 1 of 2 Garmin Dash Cam 20 Battery Replacement, Internal Assembly: step 1, image 2 of 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Battery Replacement: step 2, image 1 of 2 Garmin Dash Cam 20 Battery Replacement: step 2, image 2 of 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Battery Replacement: step 3, image 1 of 2 Garmin Dash Cam 20 Battery Replacement: step 3, image 2 of 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Battery Replacement: step 4, image 1 of 2 Garmin Dash Cam 20 Battery Replacement: step 4, image 2 of 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Battery Replacement: step 5, image 1 of 3 Garmin Dash Cam 20 Battery Replacement: step 5, image 2 of 3 Garmin Dash Cam 20 Battery Replacement: step 5, image 3 of 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Battery Replacement: step 6, image 1 of 3 Garmin Dash Cam 20 Battery Replacement: step 6, image 2 of 3 Garmin Dash Cam 20 Battery Replacement: step 6, image 3 of 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Battery Replacement, Battery: step 7, image 1 of 3 Garmin Dash Cam 20 Battery Replacement, Battery: step 7, image 2 of 3 Garmin Dash Cam 20 Battery Replacement, Battery: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the green tape overlying the pin connector with tweezers.
    • Remove the pin connector using tweezers.
    • Do not break black cord connection between motherboard and metal mount (orange circle).
  8. Garmin Dash Cam 20 Battery Replacement: step 8, image 1 of 3 Garmin Dash Cam 20 Battery Replacement: step 8, image 2 of 3 Garmin Dash Cam 20 Battery Replacement: step 8, image 3 of 3
    • This step shows the use of an incorrect tool. Only use ESD safe tools when handling the battery.
    • With the the nylon spudger, lift the battery to expose and stretch the glue. Cut the glue residue by gliding the tool from left to right.
3 other people completed this guide.
Jesse Hillman
757 Reputation
5 Guides authored
USF Tampa, Team 2-1, Cagle Fall 2016 Member of USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Members
5 Guides authored
3 Comments
An excellent article except for one major problem but, why does iFixIt not sell theses batteries or direct you on where a person could actually buy one? This knowledge is pretty much useless with out a replacement battery to actually use.
Bradley Hyman - Reply
Yeah I agree
Yousef Ghalib -
Thanks for this guide. This gave my Garmin 20 another couple of years! :)
BTW, I was able to buy the battery replacement from Amazon: https://www.amazon.com/gp/product/B07KSR...
pro cabales - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 31
All Time: 3,917
