Garmin Dezl 760LMT Speaker Replacement
  1. Garmin Dezl 760LMT Speaker Replacement, Back Panel: step 1, image 1 of 2 Garmin Dezl 760LMT Speaker Replacement, Back Panel: step 1, image 2 of 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Speaker Replacement: step 2, image 1 of 3 Garmin Dezl 760LMT Speaker Replacement: step 2, image 2 of 3 Garmin Dezl 760LMT Speaker Replacement: step 2, image 3 of 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Speaker Replacement: step 3, image 1 of 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Speaker Replacement, Speaker: step 4, image 1 of 2 Garmin Dezl 760LMT Speaker Replacement, Speaker: step 4, image 2 of 2
    • Using the sharp end of the metal probe, scrape away the wax around the base of the speaker.
    • Slide the metal probe underneath the speaker and pry upwards.
    • During reassembly, use electrical tape to hold the speaker into place.
  5. Garmin Dezl 760LMT Speaker Replacement: step 5, image 1 of 2 Garmin Dezl 760LMT Speaker Replacement: step 5, image 2 of 2
    • Grasp the speaker wire near the motherboard and lift upward to detach the connector.
Ryan Williams
763 Reputation
6 Guides authored
USF Tampa, Team 4-2, Passmore Fall 2016 Member of USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 536
