Garmin Dezl 770LMT Battery Replacement
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: step 1, image 1 of 2 Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: step 1, image 2 of 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: step 2, image 1 of 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: step 3, image 1 of 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: step 4, image 1 of 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: step 4, image 2 of 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: step 4, image 3 of 3
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: step 5, image 1 of 2 Garmin Dezl 770LMT Battery Replacement: step 5, image 2 of 2
    • Grasp the wire near the mother board and gently lift to detach the battery.
5 other people completed this guide.
Francisco Rosado
370 Reputation
4 Guides authored
USF Tampa, Team 1-3, Lacy Fall 2016 Member of USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 6,107
