Garmin Dezl 770LMT Speaker Replacement
  1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: step 1, image 1 of 2 Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: step 1, image 2 of 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Speaker Replacement: step 2, image 1 of 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Speaker Replacement: step 3, image 1 of 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Speaker Replacement, Speaker: step 4, image 1 of 2 Garmin Dezl 770LMT Speaker Replacement, Speaker: step 4, image 2 of 2
    • Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
    • Slide the spudger beneath the speaker and pull it away from the case.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Garmin Dezl 770LMT Speaker Replacement: step 5, image 1 of 2 Garmin Dezl 770LMT Speaker Replacement: step 5, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Grasp the wire connecting the motherboard and pull the wares connecting it.
    • Remember to wear an anti-static wrist strap when handling the motherboard.
Francisco Rosado
370 Reputation
4 Guides authored
USF Tampa, Team 1-3, Lacy Fall 2016 Member of USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Members
5 Guides authored
2 Comments
do u know where i can get a replacement speaker
markrushforth65 - Reply
Hi where can I buy the speaker, i hardly use my deal 770 lm and speaker gave up.
Noel Borg - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,014
