Introduction
If you find yourself on this guide, it means that you are having problems attaching your Garmin Edge 830 to its respective mount. The best solution to this is to replace the back cover . In order to do this you will have to take the device apart in its entirety. This may sound like a lot of work, but we have attached all the required steps that will have you done in a timely manner. Make sure you keep track of all your parts/screws along the way.
Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
Repeat this process a second to ensure that the glue is becoming loose.
Step 4 Motherboard
Careful: steps 4-7 are sourced from a guide that's marked as in-progress.
Remove brown and green tape with angled tweezers
One Comment
What are the steps required to put the screen back on? What glue should we use and how?
