Garmin Edge 830 USB Port Replacement
  1. Garmin Edge 830 USB Port  Replacement, Touch Display: step 1, image 1 of 1
    • Microwave the iOpener for about 30 seconds. Then place it on top of the screen, and let it sit for about 2 minutes.
    • Repeat this process a second to ensure that the glue is becoming loose.
    • Alternative: Use a heat gun or hair dryer to heat up the glue
  2. Garmin Edge 830 USB Port  Replacement: step 2, image 1 of 1
    • Use the Jimmy tool carve around the edges of the screen to break the glue seal.
  3. Garmin Edge 830 USB Port  Replacement: step 3, image 1 of 1
    • Use the iFixit plastic opening tool to pry open the screen.
  4. Garmin Edge 830 USB Port  Replacement, Motherboard: step 4, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
    • Remove brown copper tape with the FPC (not clipped). Removing of the copper tape is necessary, I didn't find a way to avoid it. Try to remove the copper tape as gentle as possible to reuse it.
    • Also remove green tape with angled tweezers and unclip in a 2nd step the FPC from the board
  5. Garmin Edge 830 USB Port  Replacement: step 5, image 1 of 1
    • Unscrew the three 1 mm screws around the perimeter of the motherboard
    • with the 2nd screw also the light senor will come of the PCB
  6. Garmin Edge 830 USB Port  Replacement: step 6, image 1 of 1
    • Use the reverse tweezers to gently pull on the silver box on top of the motherboard to remove it from the back cover.
    • Alternative: Use a plastic card in between PCB and cover.
  7. Garmin Edge 830 USB Port  Replacement: step 7, image 1 of 2 Garmin Edge 830 USB Port  Replacement: step 7, image 2 of 2
    • Locate the wire connector on the motherboard. Slowly release the wires by gently pulling with the blunt tweezers.
  8. Garmin Edge 830 USB Port  Replacement, Battery: step 8, image 1 of 1
    • Use the halberd spudger to lift and remove the battery from the back cover.
  9. Garmin Edge 830 USB Port  Replacement, USB Port: step 9, image 1 of 1
    • With the T4 screwdriver, unscrew the two 1 mm screws on the green piece located on the inside of the cable connector
  10. Garmin Edge 830 USB Port  Replacement: step 10, image 1 of 1
    • Use the halberd spudger to lift and remove the cable connector from the back cover.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 55
All Time: 1,415
