Garmin Fenix 2 Battery Replacement
  1. Garmin Fenix 2 Battery Replacement, Battery: step 1, image 1 of 3 Garmin Fenix 2 Battery Replacement, Battery: step 1, image 2 of 3 Garmin Fenix 2 Battery Replacement, Battery: step 1, image 3 of 3
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  2. Garmin Fenix 2 Battery Replacement: step 2, image 1 of 2 Garmin Fenix 2 Battery Replacement: step 2, image 2 of 2
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  3. Garmin Fenix 2 Battery Replacement: step 3, image 1 of 2 Garmin Fenix 2 Battery Replacement: step 3, image 2 of 2
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
    I am looking at the battery you suggested on eBay, and it appears that there are wires attached to it. Exactly where do these wires connect? Do they require soldering in place somewhere?
    Jamie - Reply
    Good information, but :
    - spudger not really needed, nail is enough.
    - missing the one regarding the need for a soldering iron ! The old battery needs to be unsoldered and the new one soldered to the inside wiring. Not so difficult but soldering iron needed !
    Got a spare battery on eBay (vendor is http://akku-wechsel.de). Delivery was very fast. After replacement I went from 6~8 hours life to 3~4 weeks :) So happy with the upgrade !
    Pierre Colin - Reply
11 other people completed this guide.
Brandon Barger
1,219 Reputation
5 Guides authored
IUPUI, Team 54-4, Wilson Spring 2016 Member of IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 Members
7 Guides authored
7 Comments
can you tell us exactly which battery should be used? Thanks in advance!
fabrizionannini - Reply
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
homanchris -
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
https://buy.garmin.com/en-US/US/into-spo...
L P -
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
L P - Reply
After some research on eBay the correct battery size should be PD3555 3.7V which is 500mAh.
Yang - Reply
How do I disconnect and reconnect wires from power ribbon?
Michael Rice - Reply
You need a soldering iron... I could do it without any experience doing so. Replacement battery I got online seems to give me a longer life that the original one. So happy I did the exchange ! :)
Pierre Colin -
Past 24 Hours: 7
Past 7 Days: 45
Past 30 Days: 178
All Time: 33,382
