Garmin Fenix 3 HR Battery Replacement
  1. Garmin Fenix 3 HR Battery Replacement, Battery: step 1, image 1 of 2 Garmin Fenix 3 HR Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: step 2, image 1 of 3 Garmin Fenix 3 HR Battery Replacement: step 2, image 2 of 3 Garmin Fenix 3 HR Battery Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: step 4, image 1 of 2 Garmin Fenix 3 HR Battery Replacement: step 4, image 2 of 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: step 5, image 1 of 1
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: step 6, image 1 of 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: step 7, image 1 of 1
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: step 8, image 1 of 1
    • Now attach the new battery with adhesive and reassemble.
40 other people completed this guide.
Victor Tanguy
1,329 Reputation
1 Guide authored
IUPUI, Team S1-G6, Harley Spring 2018 Member of IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 Members
4 Guides authored
29 Comments
Does anybody do It in a fenix 5?
Fernando Alcaraz - Reply
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - Reply
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
Past 24 Hours: 19
Past 7 Days: 99
Past 30 Days: 501
All Time: 67,174
