Garmin Forerunner 25 Battery Replacement
  1. Garmin Forerunner 25 Battery Replacement, Battery: step 1, image 1 of 1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: step 2, image 1 of 1
    • Pry the old battery out using a plastic spudger.
Dustin Persohn
235 Reputation
2 Guides authored
IUPUI, Team S5-G3, Baechle Spring 2018 Member of IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Members
5 Guides authored
11 Comments
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - Reply
I need to know as well. What kind of battery is it? PD…????
girlie_360 - Reply
Just look at the last picture. PD2430C1
Leandro Lind - Reply
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - Reply
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - Reply
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 80
All Time: 6,302
