Garmin Forerunner 25 Motherboard Replacement
  1. Garmin Forerunner 25 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Motherboard Replacement: step 2, image 1 of 1
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Motherboard Replacement, Motherboard: step 3, image 1 of 1
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Motherboard Replacement: step 4, image 1 of 1
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Motherboard Replacement: step 5, image 1 of 1
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
Dustin Persohn
235 Reputation
2 Guides authored
IUPUI, Team S5-G3, Baechle Spring 2018 Member of IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 821
