Garmin Forerunner 405 Button Replacement
  1. Garmin Forerunner 405 Button Replacement, Unscrew backing: step 1, image 1 of 1
    • Unscrew the four 6.35 mm Torx T5 screws securing the backing of the watch.
  2. Garmin Forerunner 405 Button Replacement, Separate Component: step 2, image 1 of 1
    • Pull the backing off the watch.
  3. Garmin Forerunner 405 Button Replacement, Separate: step 3, image 1 of 1
    • Pull the battery wires out from the motherboard slowly.
  4. Garmin Forerunner 405 Button Replacement, Unscrew: step 4, image 1 of 1
    • Unscrew one 4 mm philips screw that attaches the motherboard using a PH000 screwdriver.
    • Lift the motherboard out of the watch.
  5. Garmin Forerunner 405 Button Replacement, Pull apart: step 5, image 1 of 2 Garmin Forerunner 405 Button Replacement, Pull apart: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Push button in and pinch silver clip with tweezers.
    • Pull silver clip off the pin it is on.
    • Pull out button and replace.
Kyle Kiwczak
328 Reputation
3 Guides authored
2 Guide Comments
Where to find repair button for FR60? Can it be 3d printed? Garmin asks too much out-of-warranty
vasiljevicic - Reply
I took mine apart to find that the jammed button was actually bent. Using two pairs of needle-nose pliers, I was able to straighten it and re-use it. The watch works great now.
keithnbrauneckermil - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 3,920
