Garmin Nuvi 1390LMT Logic Board Replacement
  1. Garmin Nuvi 1390LMT Logic Board Replacement, Logic Board: step 1, image 1 of 1
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Logic Board Replacement: step 2, image 1 of 2 Garmin Nuvi 1390LMT Logic Board Replacement: step 2, image 2 of 2
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Logic Board Replacement: step 3, image 1 of 1
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Logic Board Replacement: step 4, image 1 of 1
    • Gently pull the wire ribbon connecting the screen to the logic board from the plug.
    • Be careful when unplugging the wire ribbon. It is very fragile.
  5. Garmin Nuvi 1390LMT Logic Board Replacement: step 5, image 1 of 1
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Logic Board Replacement: step 6, image 1 of 1
    • Flip the logic board over.
  7. Garmin Nuvi 1390LMT Logic Board Replacement: step 7, image 1 of 2 Garmin Nuvi 1390LMT Logic Board Replacement: step 7, image 2 of 2
    • Disconnect the harness between the battery and the logic board.
2 other people completed this guide.
Trey Ulsh
537 Reputation
3 Guides authored
Montana Tech, Team 10-4, Shirk Fall 2015 Member of Montana Tech, Team 10-4, Shirk Fall 2015
MTUM-SHIRK-F15S10G4
5 Members
3 Guides authored
One Comment
I need a replacement board for My Garmin Nuvi 1490LMT - where can I get one?
Danny - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 954
