Garmin Nuvi 200 Rear Casing Replacement
  1. Garmin Nuvi 200 Rear Casing Replacement, Rear Casing: step 1, image 1 of 2 Garmin Nuvi 200 Rear Casing Replacement, Rear Casing: step 1, image 2 of 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Rear Casing Replacement: step 2, image 1 of 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Rear Casing Replacement: step 3, image 1 of 2 Garmin Nuvi 200 Rear Casing Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
Finish Line
2 other people completed this guide.
Stuart Heater
152 Reputation
1 Guide authored
Cal Poly, Team 25-90, Amido Spring 2010 Member of Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 4,675
