Garmin Nuvi 200 Speaker Replacement
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: step 1, image 1 of 2 Garmin Nuvi 200 Speaker Replacement, Rear Casing: step 1, image 2 of 2
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: step 2, image 1 of 1
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: step 3, image 1 of 2 Garmin Nuvi 200 Speaker Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: step 4, image 1 of 1
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
  5. Garmin Nuvi 200 Speaker Replacement: step 5, image 1 of 1
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: step 6, image 1 of 3 Garmin Nuvi 200 Speaker Replacement: step 6, image 2 of 3 Garmin Nuvi 200 Speaker Replacement: step 6, image 3 of 3
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
3 other people completed this guide.
Anjelica
564 Reputation
3 Guides authored
Cal Poly, Team 25-90, Amido Spring 2010 Member of Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Members
9 Guides authored
2 Comments
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - Reply
Where can you buy replacement speakers for the Garmin units?
Brat Fry - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 7,087
