Garmin Nuvi 200w Display Assembly Replacement
  1. Garmin Nuvi 200w Display Assembly Replacement, Rear Cover: step 1, image 1 of 3 Garmin Nuvi 200w Display Assembly Replacement, Rear Cover: step 1, image 2 of 3 Garmin Nuvi 200w Display Assembly Replacement, Rear Cover: step 1, image 3 of 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Display Assembly Replacement: step 2, image 1 of 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Display Assembly Replacement: step 3, image 1 of 3 Garmin Nuvi 200w Display Assembly Replacement: step 3, image 2 of 3 Garmin Nuvi 200w Display Assembly Replacement: step 3, image 3 of 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Display Assembly Replacement: step 4, image 1 of 2 Garmin Nuvi 200w Display Assembly Replacement: step 4, image 2 of 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Display Assembly Replacement, Display Assembly: step 5, image 1 of 3 Garmin Nuvi 200w Display Assembly Replacement, Display Assembly: step 5, image 2 of 3 Garmin Nuvi 200w Display Assembly Replacement, Display Assembly: step 5, image 3 of 3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
Clayton Golz
128 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 413
