Garmin Nuvi 200w Screen Replacement
  1. Garmin Nuvi 200w Screen Replacement, Rear Cover: step 1, image 1 of 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: step 1, image 2 of 3 Garmin Nuvi 200w Screen Replacement, Rear Cover: step 1, image 3 of 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Screen Replacement: step 2, image 1 of 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Screen Replacement: step 3, image 1 of 3 Garmin Nuvi 200w Screen Replacement: step 3, image 2 of 3 Garmin Nuvi 200w Screen Replacement: step 3, image 3 of 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Screen Replacement: step 4, image 1 of 2 Garmin Nuvi 200w Screen Replacement: step 4, image 2 of 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Screen Replacement, Display Assembly: step 5, image 1 of 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: step 5, image 2 of 3 Garmin Nuvi 200w Screen Replacement, Display Assembly: step 5, image 3 of 3
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Screen Replacement, Screen: step 6, image 1 of 3 Garmin Nuvi 200w Screen Replacement, Screen: step 6, image 2 of 3 Garmin Nuvi 200w Screen Replacement, Screen: step 6, image 3 of 3
    • Using your plastic opening tool, apply pressure on the top right of the screen in order to remove some of the tabs.
    • Work the plastic opening tool around the whole screen to remove the tabs from the screen.
    • Carefully separate the screen from the front cover.
Matthew Eires
319 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 365
