Garmin Nuvi 255W Touch screen Replacement
  1. Garmin Nuvi 255W Touch screen Replacement, Power Button: step 1, image 1 of 1
    • Remove the barcode sticker at the bottom of the device.
  2. Garmin Nuvi 255W Touch screen Replacement: step 2, image 1 of 1
    • Remove two 8.4 mm T5 screws from the bottom of the device.
  3. Garmin Nuvi 255W Touch screen Replacement: step 3, image 1 of 2 Garmin Nuvi 255W Touch screen Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, carefully pry open the device.
    • Open the device carefully, making sure not to damage the gold ribbon cable that connects the screen to the motherboard.
  4. Garmin Nuvi 255W Touch screen Replacement: step 4, image 1 of 2 Garmin Nuvi 255W Touch screen Replacement: step 4, image 2 of 2
    • Remove the power button.
  5. Garmin Nuvi 255W Touch screen Replacement, Touch screen: step 5, image 1 of 1
    • Remove touch screen by using the plastic opening tool as a wedge to pry the touch screen from the case.
    • It is easiest to do this by pulling on the side tab as you wedge the touch screen away from the case.
  6. Garmin Nuvi 255W Touch screen Replacement: step 6, image 1 of 1
    • Lift the touch screen above the mother board so that its position is similar to what is shown.
    • Remove the tape connecting the gold ribbon cable circuit to the motherboard.
    • Peel the tape off slowly so there won't be any damage to the motherboard or gold ribbon cable.
  7. Garmin Nuvi 255W Touch screen Replacement: step 7, image 1 of 2 Garmin Nuvi 255W Touch screen Replacement: step 7, image 2 of 2
    • Lift up the tab connecting the gold ribbon circuit to the motherboard, using a plastic opening tool if necessary.
    • Gently remove the gold ribbon cable.
    • To insert a new screen in, attach the gold ribbon circuit to the motherboard by sliding it in place and pressing down on the tab. This may take a few attempts before it is connected successfully.
7 other people completed this guide.
Ryan
149 Reputation
1 Guide authored
Cal Poly, Team 9-3, Regan Winter 2012 Member of Cal Poly, Team 9-3, Regan Winter 2012
CPSU-REGAN-W12S9G3
5 Members
4 Guides authored
3 Comments
When do i find replacement glass
Denise - Reply
I just purchased an aftermarket touch screen with digitizer on ebay for $17 USD from a Chinese seller. Will update here with item listing # if the item is successfully installed and works.
NunOf YourBiz - Reply
I just got my aftermarket screen today. One thing worth noting is that these aftermarket screens don't have that thin adhesive shock absorbing stuff around the perimeter of the screen and it's impossible to take it off the original screen and reuse it. I used pieces of weather stripping that I cut down thinner. This isn't necessary for it to work, but it helps provide some protection.
I installed it about 3 hours ago and everything seems to work fine. How long it's going to last is another story.
If interested, you can buy the screen from ebay seller mingxing200808 Item # 400709570325. I live in NE USA and amazingly I got my screen in a little over a week after I completed the purchase. Not bad.
BTW: for those that just need the digitizer, you can pick one up on ebay for just a coupe dollars, however I have no idea how hard it would be to remove the old one and replace the new one. Looks like it might be harder than just changing the whole screen+digitizer kit.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 30
All Time: 26,804
