Garmin Nuvi 2595LMT Digitizer Replacement
  1. Garmin Nuvi 2595LMT Digitizer Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: step 1, image 1 of 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT Digitizer Replacement: step 2, image 1 of 2 Garmin Nuvi 2595LMT Digitizer Replacement: step 2, image 2 of 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT Digitizer Replacement: step 3, image 1 of 3 Garmin Nuvi 2595LMT Digitizer Replacement: step 3, image 2 of 3 Garmin Nuvi 2595LMT Digitizer Replacement: step 3, image 3 of 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT Digitizer Replacement, Digitizer: step 4, image 1 of 2 Garmin Nuvi 2595LMT Digitizer Replacement, Digitizer: step 4, image 2 of 2
    • Using the spudger, gently pry the sides of digitizer open until it lifts open and remove the digitizer from the LCD screen.
  5. Garmin Nuvi 2595LMT Digitizer Replacement: step 5, image 1 of 1
    • Heat the connection between the digitizer ribbon’s and LCD Screen's ribbon with a hot soldering to separate the two.
    • After the connection is seperated, place the digitizer screen on your work surface.
    • Take the replacement digitizer and place it over the top of the LCD screen.
    • Align the ribbon of the digitizer and lay it over the LCD ribbon.
    • Place the solder underneath the digitizer ribbon and above the LCD ribbon; the area you need to solder is silver and at the bottom of the LCD ribbon.
    • Using the soldering iron, heat up the solder and attach the two ribbons.
    • Let the solder cool for an hour.
    • The soldering iron will be hot. Be careful to not burn yourself.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 1,579
