Garmin Nuvi 2597LMT Speaker Replacement
  1. Garmin Nuvi 2597LMT Speaker Replacement, Speaker: step 1, image 1 of 2 Garmin Nuvi 2597LMT Speaker Replacement, Speaker: step 1, image 2 of 2
    • Turn your device over so the back is revealed and you can see the screws in the four corners.
    • Remove the four 3mm width by 6mm length T5 Torx screws using your screwdriver.
  2. Garmin Nuvi 2597LMT Speaker Replacement: step 2, image 1 of 3 Garmin Nuvi 2597LMT Speaker Replacement: step 2, image 2 of 3 Garmin Nuvi 2597LMT Speaker Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to pry open the device at the seam where the two halves meet, prying all along all sides if need be.
    • Do it slowly so you don't accidently rip the ribbon cable that connects the digitizer to the motherboard, as well as don't completely separate the halves as this can tear the ribbon cable.
    • Open your device from the top, so that you don't disconnect the ribbon cable.
  3. Garmin Nuvi 2597LMT Speaker Replacement: step 3, image 1 of 2 Garmin Nuvi 2597LMT Speaker Replacement: step 3, image 2 of 2
    • Use your thin spudger to gently lift the speaker off of the sticky pad and away from the casing.
  4. Garmin Nuvi 2597LMT Speaker Replacement: step 4, image 1 of 2 Garmin Nuvi 2597LMT Speaker Replacement: step 4, image 2 of 2
    • Use your soldering iron to disconnect the wires from the motherboard. Disconnect the ground wire (the black one) and the positive wire (the blue one).
    • The soldering iron is very hot and do not touch the wires to anything as it may stick to it when it cools.
    • After you have finished this step and the wire ends have cooled, you can safely set the removed speaker aside.
Patrick McNett
914 Reputation
5 Guides authored
USF Tampa, Team 1-4, Sullivan Fall 2016 Member of USF Tampa, Team 1-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G4
4 Members
5 Guides authored
4 Comments
Great article! Where can I buy replacement speaker?
Zagreb - Reply
At this time, I do not see many options other than purchasing an external speaker like http://www.ebay.com/itm/Garmin-GPS-Exter...
Other options include going to a local repair shop to see if they would sell a generic speaker, as I do not think this is a Garmin specific speaker and that one of a similar size would also work.
I hope you find this guide helpful, have a wonderful day.
Matthew Monnik -
Very good article, any idea where replacement speaker or compatible speaker can be purchased? The original comes from a company that only sells in bulk. Thanks much. John.
mrjgs70 - Reply
One might try going to a local repair shop to see if they would sell a generic speaker, as I do not think this is a Garmin specific speaker and that one of a similar size would also work. Or, an external speaker might work and are relatively cheap on sites like ebay.com. I do not know of any suppliers of this specific model.
Matthew Monnik -
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 1,422
