Garmin Nuvi 265WT Screen Replacement
  1. Garmin Nuvi 265WT Screen Replacement, Screen: step 1, image 1 of 1
    • Remove PN/Model sticker an the lower side of the device.
    • Use pentalobe screwdriver to remove the two screws underneath it.
    • Use the nylon spudger to remove the screen from the device.
    • The regular black nylon spudger should be used whenever possible, especially around glass displays and other sensitive components.
  2. Garmin Nuvi 265WT Screen Replacement: step 2, image 1 of 1
    • Lift up the screen gently and place it on the opposite side.
  3. Garmin Nuvi 265WT Screen Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to gently lift up the white rectangular snap clip that is attached to the screen.
  4. Garmin Nuvi 265WT Screen Replacement: step 4, image 1 of 1
    • Lift up the screen and you're done.
Patricia Gonzalez
337 Reputation
3 Guides authored
Texas Tech, Team 6-4, Bennett Fall 2016 Member of Texas Tech, Team 6-4, Bennett Fall 2016
TTU-BENNETT-F16S6G4
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 466
