Garmin Nuvi 2797LMT LCD Screen Replacement
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: step 2, image 1 of 3 Garmin Nuvi 2797LMT LCD Screen Replacement: step 2, image 2 of 3 Garmin Nuvi 2797LMT LCD Screen Replacement: step 2, image 3 of 3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: step 3, image 1 of 1
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: step 4, image 1 of 1
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: step 5, image 1 of 2 Garmin Nuvi 2797LMT LCD Screen Replacement: step 5, image 2 of 2
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: step 6, image 1 of 2 Garmin Nuvi 2797LMT LCD Screen Replacement: step 6, image 2 of 2
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
4 other people completed this guide.
baileykaytar
366 Reputation
2 Guides authored
2 Comments
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - Reply
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 2,384
