Garmin Nuvi 56LMT Motherboard Replacement
  1. Garmin Nuvi 56LMT Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Power off the Garmin Nuvi 56LMT before disassembling.
    • This will teach you how to replace the motherboard of the Garmin Nuvi 56LMT
  2. Garmin Nuvi 56LMT Motherboard Replacement: step 2, image 1 of 3 Garmin Nuvi 56LMT Motherboard Replacement: step 2, image 2 of 3 Garmin Nuvi 56LMT Motherboard Replacement: step 2, image 3 of 3
    • Remove the 11mm screws on the back side of the case with a T5 torx screwdriver.
    • Then, use the plastic opening tool to carefully pry the case open.
  3. Garmin Nuvi 56LMT Motherboard Replacement: step 3, image 1 of 3 Garmin Nuvi 56LMT Motherboard Replacement: step 3, image 2 of 3 Garmin Nuvi 56LMT Motherboard Replacement: step 3, image 3 of 3
    • Use the plastic opening tool to carefully pry the battery from the case.
    • Then remove the 5mm screws that are present on the motherboard.
    • Disconnect the battery from the motherboard, by pinching the wires and pulling straight out.
  4. Garmin Nuvi 56LMT Motherboard Replacement: step 4, image 1 of 1
    • Remove the ribbon connecting the motherboard to the screen by using the wedge to peel back the clasp holding the ribbon in place.
  5. Garmin Nuvi 56LMT Motherboard Replacement: step 5, image 1 of 1
    • The speaker is soldered to the motherboard so they need to be removed together. Use the plastic opening tool to remove the speaker from the case.
Ryan Bliss
101 Reputation
1 Guide authored
USF Tampa, Team S3-G5, Nance Fall 2017 Member of USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 304
