Garmin Nuvi 56LMT Speaker Replacement
  1. Garmin Nuvi 56LMT Speaker Replacement, Speaker: step 1, image 1 of 1
    • Power off you Garmin Nuvi before disassembling.
    • Use the T5 torx screwdriver to remove the four 11.0 mm screws.
  2. Garmin Nuvi 56LMT Speaker Replacement: step 2, image 1 of 2 Garmin Nuvi 56LMT Speaker Replacement: step 2, image 2 of 2
    • locate the crevice between the front and back panel.
    • Use the plastic opening tool to wedge the device open.
    • Carefully disconnect the ribbon from the ZIF connector.
  3. Garmin Nuvi 56LMT Speaker Replacement: step 3, image 1 of 2 Garmin Nuvi 56LMT Speaker Replacement: step 3, image 2 of 2
    • Locate the two 5.0 mm screws and use the T5 Torx screwdriver to remove them.
    • These screws are easily lost so keep track of them.
    • Once the screws are removed flip the motherboard over and locate the blue (+) and black (-) wires connected to the speaker.
  4. Garmin Nuvi 56LMT Speaker Replacement: step 4, image 1 of 2 Garmin Nuvi 56LMT Speaker Replacement: step 4, image 2 of 2
    • Use the crimping tool to cut the wires from the motherboard.
    • Use plastic opening tool or fingers to remove the speaker.
  5. Garmin Nuvi 56LMT Speaker Replacement: step 5, image 1 of 1
Dustin Saxon
228 Reputation
2 Guides authored
USF Tampa, Team S3-G5, Nance Fall 2017 Member of USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 116
