Garmin Nuvi 65LM Car Charger Fuse Replacement
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: step 1, image 1 of 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: step 1, image 2 of 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: step 1, image 3 of 3
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: step 2, image 1 of 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: step 2, image 2 of 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: step 2, image 3 of 3
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: step 3, image 1 of 1
    • Turn the charger compartment over and carefully dump the fuse into your hand.
Kai Ling Liang
246 Reputation
2 Guides authored
Cal Poly, Team 15-3, Amido Spring 2015 Member of Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,095
