Garmin Nuvi 680 Screen Replacement
  1. Garmin Nuvi 680 Screen Replacement, Outer Case: step 1, image 1 of 1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Screen Replacement: step 2, image 1 of 1
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Screen Replacement: step 3, image 1 of 1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Screen Replacement: step 4, image 1 of 2 Garmin Nuvi 680 Screen Replacement: step 4, image 2 of 2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Screen Replacement: step 5, image 1 of 1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Screen Replacement: step 6, image 1 of 2 Garmin Nuvi 680 Screen Replacement: step 6, image 2 of 2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Screen Replacement, Antenna: step 7, image 1 of 2 Garmin Nuvi 680 Screen Replacement, Antenna: step 7, image 2 of 2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Garmin Nuvi 680 Screen Replacement, Screen Wiring: step 8, image 1 of 1
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Garmin Nuvi 680 Screen Replacement: step 9, image 1 of 2 Garmin Nuvi 680 Screen Replacement: step 9, image 2 of 2
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
  10. Garmin Nuvi 680 Screen Replacement, Screen: step 10, image 1 of 2 Garmin Nuvi 680 Screen Replacement, Screen: step 10, image 2 of 2
    • Push the tabs towards the outside of the case, the tabs are located as shown.
    • Push the screen out of the case after the tabs are loosened.
    • Slide the screen out of the cover.
4 other people completed this guide.
Chris Marzano
968 Reputation
6 Guides authored
Cal Poly, Team 5-22, Amido Winter 2011 Member of Cal Poly, Team 5-22, Amido Winter 2011
CPSU-AMIDO-W11S5G22
5 Members
7 Guides authored
One Comment
Great instructions, thank you
I was able to fix my GPS which I thought was headed for the recyclers.
Saved me from purchasing a replacement.
knockout - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 10,514
