Garmin Rino 700 Battery Replacement
  1. Garmin Rino 700 Battery Replacement, Battery Disconnect: step 1, image 1 of 1
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Battery Replacement: step 2, image 1 of 2 Garmin Rino 700 Battery Replacement: step 2, image 2 of 2
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Battery Replacement: step 3, image 1 of 2 Garmin Rino 700 Battery Replacement: step 3, image 2 of 2
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Battery Replacement, Battery: step 4, image 1 of 3 Garmin Rino 700 Battery Replacement, Battery: step 4, image 2 of 3 Garmin Rino 700 Battery Replacement, Battery: step 4, image 3 of 3
    • Using a Phillips #000 screwdriver, remove the two 4.8 mm screws holding the battery bracket in place.
    • Using a plastic opening tool, remove the battery from the back case of the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Abigail Dugan
512 Reputation
5 Guides authored
Clemson, Team 5-5, Hunter Fall 2021 Member of Clemson, Team 5-5, Hunter Fall 2021
CLEM-HUNTER-F21S5G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 31
All Time: 1,166
