Garmin StreetPilot c330 Battery Replacement
  1. Garmin StreetPilot c330 Battery Replacement, Outer Casing: step 1, image 1 of 3 Garmin StreetPilot c330 Battery Replacement, Outer Casing: step 1, image 2 of 3 Garmin StreetPilot c330 Battery Replacement, Outer Casing: step 1, image 3 of 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Battery Replacement: step 2, image 1 of 3 Garmin StreetPilot c330 Battery Replacement: step 2, image 2 of 3 Garmin StreetPilot c330 Battery Replacement: step 2, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Battery Replacement: step 3, image 1 of 2 Garmin StreetPilot c330 Battery Replacement: step 3, image 2 of 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Battery Replacement: step 4, image 1 of 3 Garmin StreetPilot c330 Battery Replacement: step 4, image 2 of 3 Garmin StreetPilot c330 Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Battery Replacement: step 5, image 1 of 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Battery Replacement, Battery: step 6, image 1 of 3 Garmin StreetPilot c330 Battery Replacement, Battery: step 6, image 2 of 3 Garmin StreetPilot c330 Battery Replacement, Battery: step 6, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Battery Replacement: step 7, image 1 of 3 Garmin StreetPilot c330 Battery Replacement: step 7, image 2 of 3 Garmin StreetPilot c330 Battery Replacement: step 7, image 3 of 3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
Adrian Leon
173 Reputation
3 Guides authored
Cal Poly, Team 22-1, Maness Fall 2010 Member of Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 4,621
