Garmin eTrex Vista H LCD screen Replacement
  1. Garmin eTrex Vista H LCD screen Replacement, Removing Battery: step 1, image 1 of 1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Garmin eTrex Vista H LCD screen Replacement: step 2, image 1 of 1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Garmin eTrex Vista H LCD screen Replacement: step 3, image 1 of 2 Garmin eTrex Vista H LCD screen Replacement: step 3, image 2 of 2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: step 4, image 1 of 2 Garmin eTrex Vista H LCD screen Replacement, Disassembling the Garmin eTrex Vista-H Outer Case: step 4, image 2 of 2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Garmin eTrex Vista H LCD screen Replacement: step 5, image 1 of 3 Garmin eTrex Vista H LCD screen Replacement: step 5, image 2 of 3 Garmin eTrex Vista H LCD screen Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Garmin eTrex Vista H LCD screen Replacement: step 6, image 1 of 1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Garmin eTrex Vista H LCD screen Replacement: step 7, image 1 of 2 Garmin eTrex Vista H LCD screen Replacement: step 7, image 2 of 2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
  8. Garmin eTrex Vista H LCD screen Replacement, Disassembling Garmin eTrex Vista H Motherboard: step 8, image 1 of 1
    • The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
  9. Garmin eTrex Vista H LCD screen Replacement: step 9, image 1 of 1
    • There are no screws holding the motherboard in place.
    • Carefully lift the motherboard from the case.
  10. Garmin eTrex Vista H LCD screen Replacement: step 10, image 1 of 2 Garmin eTrex Vista H LCD screen Replacement: step 10, image 2 of 2
    • With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
    • Gently pull the wire ribbon from the white connector.
  11. Garmin eTrex Vista H LCD screen Replacement, LCD screen: step 11, image 1 of 3 Garmin eTrex Vista H LCD screen Replacement, LCD screen: step 11, image 2 of 3 Garmin eTrex Vista H LCD screen Replacement, LCD screen: step 11, image 3 of 3
    • After removing the motherboard, locate the two #1 Philips screws.
    • Carefully remove both screws.
  12. Garmin eTrex Vista H LCD screen Replacement: step 12, image 1 of 2 Garmin eTrex Vista H LCD screen Replacement: step 12, image 2 of 2
    • Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws.
    • Do not remove the LSC screen by lifting the sides, only the area that held the two #1 Philips screws.
  13. Garmin eTrex Vista H LCD screen Replacement: step 13, image 1 of 1
    • Insert the new LCD screen in the device.
3 other people completed this guide.
Lauren Noyes
248 Reputation
3 Guides authored
Cal Poly, Team 21-30, Regan Fall 2010 Member of Cal Poly, Team 21-30, Regan Fall 2010
CPSU-REGAN-F10S21G30
3 Members
5 Guides authored
One Comment
where can I find the LCD test
carlos gomes - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 12,115
