Gasket in the inlet valve
VauWeh
VauWeh and 2 other contributors
Last updated on September 16, 2024
No estimate
Moderate
Community-Contributed Guide
Introduction
Go to step 1
The seals of the inlet valve are under a lot of strain and need to be replaced from time to time. The replacement is easy. This will show you how to do this.
These instructions may also help with other Saeco models and with coffee makers from Philips and Gaggia—they are all made by the same manufacturer and have a very similar design.
Parts
Tools
Show more…
  1. Gasket in the inlet valve, Gasket in the inlet valve: step 1, image 1 of 1
    • Open the side panel and remove the brewing unit.
  2. Gasket in the inlet valve: step 2, image 1 of 2 Gasket in the inlet valve: step 2, image 2 of 2
    • Remove the drip tray underneath the brewing unit.
  3. Gasket in the inlet valve: step 3, image 1 of 3 Gasket in the inlet valve: step 3, image 2 of 3 Gasket in the inlet valve: step 3, image 3 of 3
    • Unscrew the four Torx T10 screws that hold in place the cover of the inlet valve.
    • Remove the cover.
    • Clean well the inside and back panel of this cover.
  4. Gasket in the inlet valve: step 4, image 1 of 2 Gasket in the inlet valve: step 4, image 2 of 2
    • You can replace the seals, it's even better if you remove the nozzle completely.
    • Replace the gaskets using a blunt tool, such as a spatula.
    • The upper gasket is larger.
    • Smear the gaskets with silicone grease.
    • To remove the nozzle, you have to unscrew the two T10 Torx screws.
  5. Gasket in the inlet valve: step 5, image 1 of 3 Gasket in the inlet valve: step 5, image 2 of 3 Gasket in the inlet valve: step 5, image 3 of 3
    • Here you see the removed socket. Note the double O-rings. They may get stuck in the opening.
    • Open the valve. To do this, the slot at the upper end must be twisted a little, then the inside comes out. Check the spring, the valve stem and the two seals. When assembling, pay attention to the correct position of the valve stamp: it must point to the water inlet side, otherwise the valve will not open!
    • Replace the seals on the nozzle and lightly grease them with food grade silicone grease.
    • If the two green O-rings no longer seal properly, the valve is no longer working. Replace the seals.
Work through the steps in reverse order to re-assemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
249,873 Reputation
283 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,757 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 57
Past 30 Days: 230
All Time: 5,119
