Gateway 600YG2 Battery Replacement
  1. Gateway 600YG2 Battery Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over.
    • Slide the battery release tab to the right to open the battery cover.
  2. Gateway 600YG2 Battery Replacement: step 2, image 1 of 1
    • Remove the battery cover using the tab on the right side.
    • Lift and remove the battery.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Aaron Brauner
51 Reputation
1 Guide authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 26
All Time: 1,662
