Gateway 600YG2 Memory Replacement
  1. Gateway 600YG2 Memory Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 Memory Replacement: step 2, image 1 of 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 Memory Replacement, Memory: step 3, image 1 of 1
    • Remove access cover by unscrewing captive screw.
  4. Gateway 600YG2 Memory Replacement: step 4, image 1 of 1
    • Slide locking tabs outward
  5. Gateway 600YG2 Memory Replacement: step 5, image 1 of 1
    • Slide memory module out
Elizabeth Mazer
78 Reputation
10 Guides authored
Cal Poly, Team 20-10, Maness Fall 2010 Member of Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Members
22 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,580
