Gateway 600YGR RAM Replacement
  1. Gateway 600YGR RAM  Replacement, RAM: step 1, image 1 of 2 Gateway 600YGR RAM  Replacement, RAM: step 1, image 2 of 2
    • Flip the computer over so that the bottom of your device is face up.
  2. Gateway 600YGR RAM  Replacement: step 2, image 1 of 3 Gateway 600YGR RAM  Replacement: step 2, image 2 of 3 Gateway 600YGR RAM  Replacement: step 2, image 3 of 3
    • Use a Philips head screwdriver and the PH1 bit to remove the indicated 5.35mm screw.
    • Remove the cover panel.
  3. Gateway 600YGR RAM  Replacement: step 3, image 1 of 3 Gateway 600YGR RAM  Replacement: step 3, image 2 of 3 Gateway 600YGR RAM  Replacement: step 3, image 3 of 3
    • Locate the indicated tabs on the edges of the top RAM board.
    • Pull the tabs outward and the RAM board will release.
    • Remove the RAM board.
  4. Gateway 600YGR RAM  Replacement: step 4, image 1 of 2 Gateway 600YGR RAM  Replacement: step 4, image 2 of 2
    • Locate the indicated tabs on the edges of the bottom RAM board.
    • Pull the tabs outward.
  5. Gateway 600YGR RAM  Replacement: step 5, image 1 of 2 Gateway 600YGR RAM  Replacement: step 5, image 2 of 2
    • You have now successfully removed the RAM boards.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 291
