Gateway ID49C07U DVD Drive Replacement
  1. Gateway ID49C07U DVD Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U DVD Drive Replacement: step 2, image 1 of 2 Gateway ID49C07U DVD Drive Replacement: step 2, image 2 of 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U DVD Drive Replacement: step 3, image 1 of 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U DVD Drive Replacement: step 4, image 1 of 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U DVD Drive Replacement, DVD Drive: step 5, image 1 of 1
    • Locate screw towards the center of the device and unscrew it
  6. Gateway ID49C07U DVD Drive Replacement: step 6, image 1 of 3 Gateway ID49C07U DVD Drive Replacement: step 6, image 2 of 3 Gateway ID49C07U DVD Drive Replacement: step 6, image 3 of 3
    • Use a metal spudger to pry off the DVD drive.
    • Once loosened, use your hand to pull the DVD drive out.
2 other people completed this guide.
Patrick McGrail
445 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 260
