Gateway ID49C07U Keyboard Replacement
  1. Gateway ID49C07U Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Keyboard Replacement: step 2, image 1 of 2 Gateway ID49C07U Keyboard Replacement: step 2, image 2 of 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Keyboard Replacement: step 3, image 1 of 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Keyboard Replacement: step 4, image 1 of 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Keyboard Replacement, Keyboard: step 5, image 1 of 1
    • Turn the laptop over and open
  6. Gateway ID49C07U Keyboard Replacement: step 6, image 1 of 3 Gateway ID49C07U Keyboard Replacement: step 6, image 2 of 3 Gateway ID49C07U Keyboard Replacement: step 6, image 3 of 3
    • Use the small metal spudger to push in each of the clips on the keyboard
  7. Gateway ID49C07U Keyboard Replacement: step 7, image 1 of 3 Gateway ID49C07U Keyboard Replacement: step 7, image 2 of 3 Gateway ID49C07U Keyboard Replacement: step 7, image 3 of 3
    • Continued
  8. Gateway ID49C07U Keyboard Replacement: step 8, image 1 of 2 Gateway ID49C07U Keyboard Replacement: step 8, image 2 of 2
    • Use the small spudger to pick up the corner
  9. Gateway ID49C07U Keyboard Replacement: step 9, image 1 of 1
    • Slide keyboard towards the screen
  10. Gateway ID49C07U Keyboard Replacement: step 10, image 1 of 2 Gateway ID49C07U Keyboard Replacement: step 10, image 2 of 2
    • Use the small spudger to slide the cable lock up on both sides of the connector and slide the cable out
2 other people completed this guide.
Ryan Howlett
273 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 668
