Gateway ID49C07U Screen Replacement
  1. Gateway ID49C07U Screen Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: step 2, image 1 of 2 Gateway ID49C07U Screen Replacement: step 2, image 2 of 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: step 3, image 1 of 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: step 4, image 1 of 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: step 5, image 1 of 1
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: step 6, image 1 of 2 Gateway ID49C07U Screen Replacement: step 6, image 2 of 2
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: step 7, image 1 of 2 Gateway ID49C07U Screen Replacement: step 7, image 2 of 2
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: step 8, image 1 of 1
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: step 9, image 1 of 3 Gateway ID49C07U Screen Replacement: step 9, image 2 of 3 Gateway ID49C07U Screen Replacement: step 9, image 3 of 3
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: step 10, image 1 of 3 Gateway ID49C07U Screen Replacement: step 10, image 2 of 3 Gateway ID49C07U Screen Replacement: step 10, image 3 of 3
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: step 11, image 1 of 2 Gateway ID49C07U Screen Replacement: step 11, image 2 of 2
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: step 12, image 1 of 1
    Tool used on this step:
    Buy
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: step 13, image 1 of 2 Gateway ID49C07U Screen Replacement: step 13, image 2 of 2
    • Hold the tape back with one hand and pull the connector out
2 other people completed this guide.
Ryan Howlett
273 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 450
