Gateway KAV60 LT2016U Key Replacement
  1. Gateway KAV60 LT2016U Key Replacement, Battery: step 1, image 1 of 3 Gateway KAV60 LT2016U Key Replacement, Battery: step 1, image 2 of 3 Gateway KAV60 LT2016U Key Replacement, Battery: step 1, image 3 of 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Key Replacement, Key: step 2, image 1 of 2 Gateway KAV60 LT2016U Key Replacement, Key: step 2, image 2 of 2
    • Any key on the keyboard can be replaced.
    • Insert the plastic opening tool under the key to be replaced.
  3. Gateway KAV60 LT2016U Key Replacement: step 3, image 1 of 1
    • The key is easily removed by applying force to the plastic opening tool until the key pops off.
Lydia Benjock
1,216 Reputation
10 Guides authored
Clemson, Team 14-3, Benson Fall 2013 Member of Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Members
22 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 733
