Gateway LT2104u RAM Replacement Guide
  1. Gateway LT2104u RAM Replacement Guide, RAM: step 1, image 1 of 1
    • Locate the the "L" shaped cover on the back, lower right hand side the device. Using a Philips screwdriver, remove the screw holding it in.
  2. Gateway LT2104u RAM Replacement Guide: step 2, image 1 of 2 Gateway LT2104u RAM Replacement Guide: step 2, image 2 of 2
    • Gently lift the cover until it detaches from the device.
  3. Gateway LT2104u RAM Replacement Guide: step 3, image 1 of 2 Gateway LT2104u RAM Replacement Guide: step 3, image 2 of 2
    • Gently push the levers on each side of the stick of RAM away from each other until the RAM springs into a 45° angle.
  4. Gateway LT2104u RAM Replacement Guide: step 4, image 1 of 1
    • Carefully remove the stick of RAM by pulling at the same 45° angle the RAM is currently at until it detaches from the device.
  5. Gateway LT2104u RAM Replacement Guide: step 5, image 1 of 1
    • When inserting the new stick of ram, be sure to insert it at the same 45° angle that the old stick of ram was taken out at. Press the stick of RAM down until it clicks into place.
Chris Sullivan
234 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 466
