Gateway MA6 Laptop Cooling Assembly Replacement
Chris Naughton
Chris Naughton and 5 other contributors
Last updated on June 22, 2019
15 minutes
Moderate
Missing Steps
Introduction
Go to step 1
The cooling assembly is made up of a cooling fan and a large piece of copper to help dissipate heat out of the bottom of your laptop. Over time, the fan can wear out and it will need to be replaced.
Tools
  1. Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: step 1, image 1 of 2 Gateway MA6 Laptop Cooling Assembly Replacement, Cooling Assembly: step 1, image 2 of 2
    • Loosen the seven 6 mm Phillips #0 screws on the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  2. Gateway MA6 Laptop Cooling Assembly Replacement: step 2, image 1 of 2 Gateway MA6 Laptop Cooling Assembly Replacement: step 2, image 2 of 2
    • Pull upwards on the top of the back cover to remove it.
  3. Gateway MA6 Laptop Cooling Assembly Replacement: step 3, image 1 of 1
    • Remove the four 9 mm Phillips #0 screws from the cooling assembly.
  4. Gateway MA6 Laptop Cooling Assembly Replacement: step 4, image 1 of 3 Gateway MA6 Laptop Cooling Assembly Replacement: step 4, image 2 of 3 Gateway MA6 Laptop Cooling Assembly Replacement: step 4, image 3 of 3
    • Gently and carefully remove the cooling assembly to avoid ripping the wire attaching it to the computer.
    • Gently flip the cooling fan assembly upside-down on the computer surface.
    • Carefully grab the wire attached to the computer and pull away from the port.
    • The cooling fan is now safe for removal.
  5. Gateway MA6 Laptop Cooling Assembly Replacement: step 5, image 1 of 1
    • When reinstalling heat sink and fans clean off the old thermal paste from both the heat sink and the CPU and then add new paste to CPU
    • If your unfamiliar with applying thermal paste How to Apply Thermal Paste
2 other people completed this guide.
Chris Naughton
705 Reputation
5 Guides authored
Cal Poly, Team 6-2, Forte Spring 2014 Member of Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 834
