Gateway MA6 Laptop Hard Drive Replacement
  1. Gateway MA6 Laptop Hard Drive Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Hard Drive Replacement: step 2, image 1 of 3 Gateway MA6 Laptop Hard Drive Replacement: step 2, image 2 of 3 Gateway MA6 Laptop Hard Drive Replacement: step 2, image 3 of 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Gateway MA6 Laptop Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
  4. Gateway MA6 Laptop Hard Drive Replacement: step 4, image 1 of 2 Gateway MA6 Laptop Hard Drive Replacement: step 4, image 2 of 2
    • Press thumb down firmly on the hard drive and pull outwards to the side.
3 other people completed this guide.
Chris Naughton
705 Reputation
5 Guides authored
Cal Poly, Team 6-2, Forte Spring 2014 Member of Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Members
20 Guides authored
One Comment
It only took 2 minutes once I found te right screwdriver. Great aid!
Reed Roloff - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,887
