Gateway MA6 Laptop Wireless Card Replacement
  1. Gateway MA6 Laptop Wireless Card Replacement, Battery: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop Wireless Card Replacement: step 2, image 1 of 3 Gateway MA6 Laptop Wireless Card Replacement: step 2, image 2 of 3 Gateway MA6 Laptop Wireless Card Replacement: step 2, image 3 of 3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: step 3, image 1 of 2 Gateway MA6 Laptop Wireless Card Replacement, Wireless Card: step 3, image 2 of 2
    • Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
    • The screw will remain in the backplate.
    • Lift upwards on the back plate to remove it.
  4. Gateway MA6 Laptop Wireless Card Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to gently pry upwards on the two connecting cables to remove them.
  5. Gateway MA6 Laptop Wireless Card Replacement: step 5, image 1 of 1
    • Remove the 2 mm Phillips #0 screw.
    • The card will lift itself up 30° after the screw has been removed.
  6. Gateway MA6 Laptop Wireless Card Replacement: step 6, image 1 of 2 Gateway MA6 Laptop Wireless Card Replacement: step 6, image 2 of 2
    • Hold the WiFi card on both sides and pull outwards to remove it.
Chris Naughton
705 Reputation
5 Guides authored
Cal Poly, Team 6-2, Forte Spring 2014 Member of Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Members
20 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 751
