Gateway MA7 RAM Replacement
  1. Gateway MA7 RAM Replacement, RAM: step 1, image 1 of 1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Push the locking tab over to the right away from the battery to unlock it from the laptop.
    • Hold the additional locking tab to the left while pulling out the battery.
  2. Gateway MA7 RAM Replacement: step 2, image 1 of 2 Gateway MA7 RAM Replacement: step 2, image 2 of 2
    • Remove the following screws securing the plastic panel from the bottom of the laptop:
    • Seven 6 mm Phillips #0
  3. Gateway MA7 RAM Replacement: step 3, image 1 of 3 Gateway MA7 RAM Replacement: step 3, image 2 of 3 Gateway MA7 RAM Replacement: step 3, image 3 of 3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 RAM Replacement: step 4, image 1 of 2 Gateway MA7 RAM Replacement: step 4, image 2 of 2
    • Push the two metal tabs (holding the module in place) apart in order to release it.
  5. Gateway MA7 RAM Replacement: step 5, image 1 of 2 Gateway MA7 RAM Replacement: step 5, image 2 of 2
    • Pull the ram out of the motherboard at a 45 degree angle.
  6. Gateway MA7 RAM Replacement: step 6, image 1 of 3 Gateway MA7 RAM Replacement: step 6, image 2 of 3 Gateway MA7 RAM Replacement: step 6, image 3 of 3
    • Repeat steps 4 & 5 for the other memory module.
2 other people completed this guide.
Tim Rose
392 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,639
