Gateway MD2614u RAM Replacement
  1. Gateway MD2614u RAM Replacement, Back Cover: step 1, image 1 of 1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u RAM Replacement: step 2, image 1 of 1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u RAM Replacement: step 3, image 1 of 1
    • Lift off the cover.
  4. Gateway MD2614u RAM Replacement, RAM: step 4, image 1 of 1
    • Identify the RAM, which is a stack of two green cards in the upper left-hand corner.
  5. Gateway MD2614u RAM Replacement: step 5, image 1 of 1
    • There are silver tabs on both sides of the ram. Simultaneously push the silver tabs outward.
  6. Gateway MD2614u RAM Replacement: step 6, image 1 of 1
    • The card pops up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card to the right horizontally.
  7. Gateway MD2614u RAM Replacement: step 7, image 1 of 1
    • Follow the same steps for the second RAM card, which is under the one you just removed.
Toni Pipes
333 Reputation
7 Guides authored
Cal Poly, Team 21-31, Regan Fall 2010 Member of Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 4,383
