Gateway MS2285 Hard Drive Replacement
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: step 1, image 1 of 1
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: step 2, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: step 2, image 2 of 2
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: step 3, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Release The Battery: step 3, image 2 of 2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: step 4, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Remove The Battery: step 4, image 2 of 2
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: step 5, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: step 5, image 2 of 2
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: step 6, image 1 of 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: step 6, image 2 of 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: step 6, image 3 of 3
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: step 7, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: step 7, image 2 of 2
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: step 8, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: step 8, image 2 of 2
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: step 9, image 1 of 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: step 9, image 2 of 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: step 9, image 3 of 3
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: step 10, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: step 10, image 2 of 2
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
Chris mello
331 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 35
All Time: 4,082
