Gateway MS2370 Keyboard Replacement
  1. Gateway MS2370 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Keyboard Replacement: step 2, image 1 of 1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Keyboard Replacement: step 3, image 1 of 1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
  5. Gateway MS2370 Keyboard Replacement: step 5, image 1 of 1
    • Carefully lift the keyboard molding out.
  6. Gateway MS2370 Keyboard Replacement: step 6, image 1 of 1
    • Use the plastic spudger again to pry the keyboard tabs from the laptop.
  7. Gateway MS2370 Keyboard Replacement: step 7, image 1 of 1
    • Slowly lift the keyboard from the laptop.
  8. Gateway MS2370 Keyboard Replacement: step 8, image 1 of 2 Gateway MS2370 Keyboard Replacement: step 8, image 2 of 2
    • Carefully unplug the ribbon cable attached to the motherboard.
    • The ribbon cable is extremely delicate, handle with care
  9. Gateway MS2370 Keyboard Replacement: step 9, image 1 of 1
    • Lift and remove the keyboard from the computer.
Mathieu Bolduc-Clayton
518 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,028
