Gateway NE52203u Touchpad Assembly Replacement
  1. Gateway NE52203u Touchpad Assembly Replacement, Touchpad Assembly: step 1, image 1 of 2 Gateway NE52203u Touchpad Assembly Replacement, Touchpad Assembly: step 1, image 2 of 2
    • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
    • Remove 5 6.0 mm Phillip #00 screws from under cover.
  2. Gateway NE52203u Touchpad Assembly Replacement: step 2, image 1 of 1
    • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
  3. Gateway NE52203u Touchpad Assembly Replacement: step 3, image 1 of 2 Gateway NE52203u Touchpad Assembly Replacement: step 3, image 2 of 2
    • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
  4. Gateway NE52203u Touchpad Assembly Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
  5. Gateway NE52203u Touchpad Assembly Replacement: step 5, image 1 of 3 Gateway NE52203u Touchpad Assembly Replacement: step 5, image 2 of 3 Gateway NE52203u Touchpad Assembly Replacement: step 5, image 3 of 3
    • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
    • First flip open the flap covering the ribbon using a spudger or fingernail.
    • Second gently pull the ribbon away from the port.
Stephen Spees
542 Reputation
4 Guides authored
Baylor, Team 2-1, Grigsby Spring 2015 Member of Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 765
