Gateway NE52214U Motherboard Replacement
  1. Gateway NE52214U Motherboard Replacement, Battery: step 1, image 1 of 1
    • Make sure to power down and turn off the laptop before proceeding with this guide.
    • Flip over the laptop.
  2. Gateway NE52214U Motherboard Replacement: step 2, image 1 of 2 Gateway NE52214U Motherboard Replacement: step 2, image 2 of 2
    • Slide the tab to the left and hold the tab there.
    • While holding down the sliding tab, remove the battery from the device.
  3. Gateway NE52214U Motherboard Replacement, Upper Case: step 3, image 1 of 2 Gateway NE52214U Motherboard Replacement, Upper Case: step 3, image 2 of 2
    • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
  4. Gateway NE52214U Motherboard Replacement: step 4, image 1 of 1
    • Flip over the laptop and open it so the screen is facing you.
  5. Gateway NE52214U Motherboard Replacement: step 5, image 1 of 1
    • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
  6. Gateway NE52214U Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
  7. Gateway NE52214U Motherboard Replacement: step 7, image 1 of 2 Gateway NE52214U Motherboard Replacement: step 7, image 2 of 2
    • Gently lift and remove the motherboard off of device.
    • This will also remove the fan from the device but it will remain attached to the motherboard.
Kelsey Rodrigues
495 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 343
