Gateway NV52 Hard Drive Compartment Replacement
  1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: step 1, image 1 of 1
    • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
  2. Gateway NV52 Hard Drive Compartment Replacement: step 2, image 1 of 1
    • Lift up the base cover from the the top with your hands to a 90 degree angle.
    • Remove the base cover and place it in a safe and dry place.
  3. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: step 3, image 1 of 1
    • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
  4. Gateway NV52 Hard Drive Compartment Replacement: step 4, image 1 of 3 Gateway NV52 Hard Drive Compartment Replacement: step 4, image 2 of 3 Gateway NV52 Hard Drive Compartment Replacement: step 4, image 3 of 3
    • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
    • Lift the Hard Drive to a 90 degree angle and out of its slot.
    • Place the Hard Drive in a designated zone.
2 other people completed this guide.
Tim En
557 Reputation
4 Guides authored
Cal Poly, Team 7-24, Regan Spring 2014 Member of Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 996
